Old 02-25-2009, 07:29 PM   #1
reknapp52
reknapp52's Avatar
Liked 7 Times in 5 Posts
Default Re: Frozen block
Have you pulled the oil dipstick and checked it? If it shows about 3 quarts above the full line, you've got cracks inside, probably in the lifter valley area.
reknapp52 is offline   Reply With Quote
Old 02-26-2009, 08:04 AM   #2
buzzinhalfdozen
Liked 11 Times in 8 Posts
This may be an odd question, but why would you leave water in any engine, the minerals in water attack almost every part of the cooling system. My suggestion (take it for what it's worth) drain the block and rad. go buy 2 gals. of premix antifreeze and pour it in, this would eliminate the potential for freezing and the antifreeze helps stop the errosion effects of water. Joe.....P.S. I've been told by may Rad. manufactures that you should use distilled water in a race motor as all the nasty stuff has been boiled away
Joe Buchanan SS/BX 3117
