Old 02-25-2009, 10:23 AM   #1
Thurston
Thurston's Avatar
Default Re: Battery Trouble
Rick, Glad to hear that. Base on all the information I could find about batteries I just purchased an Odyssey PC-1200 for my Roadster (no alternator) looks like the right decision. I also purchased their 25amp charger.
How much charging are you doing at the track, after every round, every other round, or once per day??
Thanks
JT
Thurston is offline   Reply With Quote
Old 02-25-2009, 11:34 AM   #2
krugracing12
An alternator is the way to go. I had one put on my new dragster, and unless I forget to turn the fans or something off, I never have to charge it. I check it constantly with a meter and it is always ready to go. It was a good investment, I will never have another drag car without one.
krugracing12 is offline   Reply With Quote
Old 02-25-2009, 09:14 PM   #3
Rick Blake
Rick Blake's Avatar
Thanks
JT
I have hot lapped rounds without charging, but generally set it on 20 amps until voltage reaches mid 13 volts and then switch to 2 amps between rounds. Don't let the voltage go above 14 volts. Congrats on your choice, you'll like it....!!!!!!
Rick Blake
Rick Blake 2395 SG, SC, SP
Rick Blake is offline   Reply With Quote
Old 02-25-2009, 09:40 PM   #4
dak
Odessey batteries IMHO are the 1 of the best on the market... they hold a charge longer the a regular battery. light weight. huge cranking power.. I have 1 in my race car.. My buddy put 1 in his sandbuggy...and in his airplane...
dak is offline   Reply With Quote
Old 02-26-2009, 11:04 AM   #5
Thurston
Thurston's Avatar
Rick Blake
Thanks Rick, I'll put your advice to good use.
JT
Old 02-28-2009, 11:09 AM   #6
Glenn Quinn
Glenn Quinn's Avatar
I have one of the Odyssey PC-1200 in the car and one in the trailer for the winch. If the one in the car takes a dump I can just switch out batteries without a lot of trouble. I charge both during the week, and they have lasted three years so far.
Glenn Quinn is offline   Reply With Quote
