Old 02-22-2009, 09:23 PM   #1
west coast
Liked 223 Times in 73 Posts
Default Adjustable front struts for Mustang who's to run?
Fox body Mustangs 79-93 with an auto. Who has the better struts? Single adjustable or double adjustable. Is doubles worth the extra money in a 11 to 12 second stocker. Singles are about $100 each doubles are about $450 each.
west coast is offline   Reply With Quote
Old 02-22-2009, 11:28 PM   #2
RPM5595
RPM5595's Avatar
Liked 32 Times in 14 Posts
Default Re: Adjustable front struts for Mustang who's to run?
When I ran my 89 in Stock I used normal 90/10's with Moroso Trick front springs. Make sure the control arm bushings fit smoothly in the K member with no bind. I would 60' in the low to mid 1.50's when it ran low 12's in N/SA or G/FIA. Going high 11's or low 12's you dont need double adjustables IMO. For the money I would buy the single adjustables from Strange Engineering. Hope this helps.
Jay
Jay Roeder
facebook.com/racefuelsales
Former N/SA , Soon to be SS/AS, Renegade Race Fuel dealer
RPM5595 is offline   Reply With Quote
Old 02-23-2009, 12:00 AM   #3
Notch1320
I'm currently using QA1's.
Shawn Allsup
K/S 718
Notch1320 is offline   Reply With Quote
Old 02-23-2009, 12:18 AM   #4
Jeff Lee
Jeff Lee's Avatar
Contact Calvert Racing, he was swapping struts quite a bit in testing the new CJ500. I'll bet he has a new product.
Jeff Lee 7494 D/S '70 AMX
Old 02-23-2009, 10:45 AM   #5
buzzinhalfdozen
Liked 11 Times in 8 Posts
Run the Alum. bodied single Qa1's on my Edge mustang, work fine and shed a few pounds off the nose. Joe
Joe Buchanan SS/BX 3117
Old 02-23-2009, 11:32 AM   #6
Chris1529
Liked 70 Times in 29 Posts
in my experience, the adjustable struts only fit an 87-up. They have larger front brakes and different spindles from the 79-86. The QA1's wouldn't fit my 84 model and Strange only lists their adjustable units for 87-up.
Chris Bowman
The Mountain State Mustang
1984 Mustang GT350
Old 02-23-2009, 12:46 PM   #7
John Quinn
I am building my 85 using 94-95 spindles so that the 87 and up struts will fit. I have also been told those spindles will improve the handling. The spindles are a bolt in upgrade but need some minor accessories if you retain the old style struts. I believe a different tie rod emd is also used, I am at work and don't have the info at hand.
It is such a common swap that Late Model Restoration even has a kit.
http://www.latemodelrestoration.com/...1&comp=LRSeven
John Quinn is offline   Reply With Quote
Old 02-23-2009, 01:01 PM   #8
Chris1529
My car is a GT 350. I had to put a ball joint on it last spring before I left for Mooresville.
I got one for an 84 GT and it did not fit. I went back and asked for one for an 84 SVO and it fit.
My car, being a 20th anniversary model, must have a conglomeration of parts, but the adjustable struts still did not fit.
Chris Alstons chassis works also makes a double adjustable strut for the fox body cars.
I have run lakewoods on my car for 10 years.
Chris Bowman
1984 Mustang GT350
Old 02-23-2009, 04:00 PM   #9
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Santuff if you have more money than you know what to do with, or QA-1's if you want the most bang for the buck. Works on my car.
Sean
Sean Marconette
84 Mustang
5060 SS/N
