Liked 138 Times in 22 Posts
who makes good light weight spool & gears
BILLY HARPER |
Mark Williams aluminum spool. They also lighten gears.
Shawn Blair 6383 SS 634 STK |
Moser engineering///// the best !!!!!
Danny Waters, Sr / 73 Duster "340" |
Liked 216 Times in 77 Posts
I would second the moser stuff. If you use the moser alum spool you will most likely have to send them your axles to have the splines cut a little longer as they run the splines in the spool all the way from one end to the other. It cost a little more to do it this way but looks to make it alot stronger and less likely to strip the splines out of the alum spool as I have seen with some of the others.
Liked 242 Times in 81 Posts
Mark Williams sets the standard that others shoot for. I have run the MW aluminum spool and light weight axles since 1999 thousands of hits never a problem. That is with a 7000 rpm stick shift launch. Now that the car is sold and has an slush-o-matic in it the parts should last forever.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Banned
M/W is far better quality than Moser..but more expensive too..used both..no real problems with Moser...I just like to have better quality stuff...
Mark Williams has my vote. Mike Pustelny from MPR is a dealer for them and he can get you the best prices on their products. 810-798-8998.
Joe Martens AA/Stock 3969 Last edited by Joe Martens; 02-14-2009 at 05:00 PM. |
Not trying to hyjack the thread but i was wondering. How much has anyone picked up going from a normal 30 spline moser kit to a good light weight package? I know its making your rotating parts lighter which is always a good thing but how much will it actually help. Also anything about ceramic in the rear?
Liked 9 Times in 3 Posts
Guys i'm not trying to stir the pot here. But in my 0pinion the moser stuff , isn't really that nice i think their quality is poor . If you want cheap than go with Moser . I have run a chassis shop for nearly 20 years, and have used parts from Moser ,Stange, and Mark Williams. The M/W is stuff is very well made but kinda exspensive . the parts from Strange eng. are very well made , and priced much better. My first choice is always Strange.
Liked 83 Times in 20 Posts
Moser Aluminum spool lasted me for about 20 runs and then the ring gear side broke. This was last year at the Memphis Tn. points meet. I replaced the spool with a steel Moser spool and put many runs on it without a problem.
John Duzac D/S 4448 STK |
