Old 02-12-2009, 04:56 PM   #1
Paul Hellenberg
Default Re: Pomona GT/MA (-1.41 under) does it get HP ???
7 HP
It is in the Stock Classification
Paul
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Paul Hellenberg is offline   Reply With Quote
Old 02-12-2009, 05:47 PM   #2
Originally Posted by Paul Hellenberg View Post
7 HP
Paul
Did he withdraw or not? If he withdrew, then he got credit for the entry and he technically wasn't there.
Sounds like a legal issue.
Also, how can that motor have a manual trans GT factor, when it only came in a Caprice?
Old 02-12-2009, 06:18 PM   #3
Paul Hellenberg
Hello Mark
I do not have any inside information.
I know a bunch left before 1st round and since they were a long way from home, and I understand.
I believe that the 265 was originally an automatic combination.
Paul
Old 02-12-2009, 10:01 PM   #4
5919 SSKA
Liked 19 Times in 5 Posts
The Hp per the way I read the rule is AUTOMATIC once the run is made...weather he withdraws or not!
It's really about time that combo got hit, as he's always been REAL FAST with that particular engine.
As for transmission---I believe the "Any" engine/transmission combo takes care of that.
I doubt 7Hp (if that's what it is) will slow it down THAT MUCH. Should be something like 70/75 lbs...so, a big -1.34 or so under now....LOL
Good run....should of shut off at 1000' but, good run!
Racing web page
5919 SSKA is offline   Reply With Quote
Old 02-13-2009, 02:04 AM   #5
55 Chevy
55 Chevy's Avatar
Liked 20 Times in 15 Posts
So does this HP hit apply to cars running the 265 in traditional Super Stock?
55 Chevy is offline   Reply With Quote
Old 02-13-2009, 03:53 AM   #6
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Thumbs up Re: Pomona GT/MA (-1.41 under) does it get HP ???
No. Jim
Old 02-13-2009, 05:35 AM   #7
Paul Hellenberg
Jim
The HP change only applies to this specific engine which is a late model 265.
Paul
Paul Hellenberg
3881 SS and STK
paul@hellenberg.us
Old 02-13-2009, 09:37 AM   #8
55 Chevy
55 Chevy's Avatar
Jim & Paul
Thanks for that info.
Just curious, how does that combo come to get 265 cid? Is it a 262 block?
Thanks
Allan
Old 02-13-2009, 02:03 PM   #9
Bryan Worner
Liked 535 Times in 86 Posts
7 hp in GT/MA (14lbs weight break) would be 98 lbs. Should slow it down a tenth....if he was at minimum weight????
Bryan Worner is offline   Reply With Quote
Old 02-13-2009, 08:37 PM   #10
Tom Meyer
Liked 354 Times in 120 Posts
Smile Re: Pomona GT/MA (-1.41 under) does it get HP ???
Ron,s motor combo came from a New York taxi cab and was the brainchild of him and Gene Bichlmeier. It has a 3 in stroke and is basic lt1 setup but is an iron head motor. The reverse cooling is a problem with them as any lt1 because of the extra water holes in the deck and cly head so runing a aftermarket block is not a bolt together deal. It also also has a 5.8 or 9 something long rod that was just reaproved by NHRA not to long ago. In running GT/MA you best have your act togrther with the likes of bob dennis and kevin murpfy with there caddy motors then don,t foget about town and shaffer with 2bl 350s this group was always on the top of the sheet. His run was made in bracket trim and was the first run on the engine since last april when he broke it. All for not when the weather deal took over. I know Ron feels bad over the deal and will move on. But is not our class perfromace based or that the way it started out to be. Its not for us to shoot arrows at him but to shake his hand and say way to go you done good. Way to go Ron and call if you guys need bail money on your trip {wish I was there}. Tom
Tom Meyer 5240 SS Stock ???
