Liked 2 Times in 2 Posts
can anyone tell me how many hp it takes to run 8.70's or so in a 2000 lb. dragster.
thanks in advance for any info. |
Roughly about 500-550 HP when I first started racing years ago I had a 1800 pound dragster and a 630HP SBC and I was running upper 8 teens to 20s on methanol but that was 15 years ago. Hope this helps.
S&W 235" 4-link 880 H.P. 1915 with me in it. Best time was an 7.50. Average was 7.55-7.57 You can work backwards from there. I am guessing 725-750 should do it.
Liked 3 Times in 2 Posts
Back when S/C was just starting out, a friend of mine had a lil 331 Aluminum headed motor in his 1650# dragster and would run 8.8's all day long. We figured it to be somewhere around 575-600hp.
NHRA: Comp 2200 - S/C 2201 NMRA 2012 Outlaw 10.5 #10 |
ive got a small block dragster weighs 1800 and it runs 8.70 all day,its only a 357cu motor roughly about 650 hp....
My uncle also has a name brand 4-link car with a roughly 675-725 HP 421 SBC and he runs 8.0's to high 7.90's depending on air. I was probley a little conservitive on my intial numbers I would assume just over 600 would get it done but 2000 pounds is pretty heavy for a dragster unless you are considering driver weight into that number.
#7 | |
