#1 | |
JJ Nance '06 Don Davis C5 Corvette |
Eddie, he holds up 37 fingers for you!!!!!!!!!!!
Jeff Beckman 318J ET, SG 318T SC |
"while I hammered the brakes to slow down to a 9.95"
JJ you ment to say you pushed softly on your brake pedal ![]() BB |
Ryan, most roadsters like mine and yours have the cell in back. It will work fine, WD 40 will be your new best freind with BEER/Alcohol for fuel.
Banned
Oopps
Thanks for the info john i have ran alchohol before and have a belt drive pump already just wasnt sure if it would work with tank in back i had the tank in front on the car i had it on before. Dont really want to mess with buying a new pump and all that mess the car works fine like it is on Q16 just really wanted to run the alchohol for the cooling part. Thanks for all the input from everyone.
Ryan Dillman 316K S/G |
Charlie ,,, you nailed my plan for 2009
"and I'm really feeling that with some testing in the converter and tire area, these guy will easily be into the 170's " Dave ,, $20K is close When I switched last year from a small block , it cost me $23K ,,,, I had to get Complete motor , engine plate, headers , gears , different converter ( The bad *** Red one from Hughs ) , Transmission , tires , box to shift on time and Diapers/Toilet paper for me ,,,, ( hey , I hope my wife isn't reading this post ,,,,Turning Money into Noise !! ) ---- On the plus side the sell of my Small Block , trans , gears , converter , tires etc ,,,, did get me almost 1/2 the $ back ( one of my friends is putting the Small Block in a Chevette ![]() Colorful 37
Eddie Arnold Jr. 3934 SC, SG |
Dave
It would be a belt drive pump with tank in back with carb......... i had a nova that had the tank in the front and it did fine just worried about it being in the back on the roadster.
Make sure its a good belt drive pump BLP etc and that the fuel isnt forced to climb anymore then 12 inch in height from cell exit height to imput on pump and run a minimum of #8 return line all the way to the rear tank. Been running alky a very long time and front tank is better but rear tank worked ok.
Liked 4 Times in 2 Posts
The speed thing is self governing....for us.....we go high 160's and its still managable..the problem is the motors are expensive and don't last near as long....
we are probably one of the guys you are talking about....but I don't think we will be going any faster.....we feel this is kind of the ceiling....I know some guys are going 170's....but being on the stop so long is boring...and if you have an issue....the issue lasts longer....which in turn causes the car to be screwed up.... I can tell you ....its not that easy to get a high horsepower car good on the stop.....so you slower guys should welcome the guys that want to go over 170....because its tough to make them consistent.... I still think about 165 is the place to be.....about 1050 hp........my 2 cents.... cbs |
