#9 | |
- N/A - Any compression up to say 13.5:1 - Any engine that uses a factory stroke, can be factory block or aftermarket - Must be 23 degree heads - Any Automatic (no more than 3 gears unless factory equipped), any manual up to 5 speeds - Any rear - Any suspension Basically a Super Stock class where any 23 degree head can be used, any compression, any rods and that would be a Pro Stock class but make it where the engines have to be as follows (GM for example) - 283, 302, 305, 307, 327, 350, 400, 396, 427, 454 Cant be strokers That would put alot of bracket racers in competition with a 427 etc in their car,,,,,,,,, Classes should be run in an index if needed Min race weight for example,, 3200 pounds for small block cars and 3400 for big block cars |
