Old 11-12-2008, 10:52 PM   #10
John DiBartolomeo
Default Re: Motorhome help
We (http://www.drcraceproducts.com) do quite a bit of motorhome hitches. Your only concern should be a hitch which is mounted properly. Gasoline chassis motorhomes need to use the weight distribution bars as well as some sort of sway control. Diesel pushers with air ride suspension don't require weight distr. bars but by installing them loosely, they will take out the bounce you'll get when you hit bumps. You won't have any problems towing with this unit and if this is your first motorhome, I think you're really going to be happy you have it. If you have any questions, feel free to call us at 609-209-9979.
John DiBartolomeo
DRC Race Products
DragRacingActionOnline.com
