Old 07-22-2008, 03:45 PM   #12
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: Combine?????
I wouldn't have a problem with full-pound weight breaks.
In regards to Sticks vs Autos, the devil is in the details, although I think it's worth noting that if the class index is the same or within .05, that you should be able to combine the classes with a slight weight break one way or the other, depending on which class index is higher or lower.
As Billy pointed out, the cars are factored separately. If the cars have the same index (see caveat above), there's no reason why they the cars shouldn't run together. If the parity isn't there, then theoretically, the combinations are not factored properly.
$.02,
