Old 01-23-2025, 01:06 PM   #41
Liked 1,836 Times in 417 Posts
Default Re: Lifters In Stock Eliminator
Originally Posted by Rick J View Post
Well, oversized lifters are in NHRA Stock Eliminator, just so you know.
There's all sorts of illegal stuff out there in Stock Eliminator.
That doesn't mean you should do it. Or that you can pass tech if you do.
Old 01-23-2025, 01:06 PM   #42
Rick J
Liked 73 Times in 37 Posts
Lifter diameter needs to be defined, so does lifter bore angle.
Rick J is offline   Reply With Quote
Old 01-23-2025, 01:13 PM   #43
Larry Merk
Larry Merk's Avatar
Liked 314 Times in 113 Posts
It is NOT an UNWRITTEN rule.
Page 21 of the NHRA 2025 Rule Book states "On the other hand, as to performance equipment, it is the general rule that unless optional performance equipment or performance-related modification is specifically permitted by this Rulebook, it is prohibited."
Section 11 covering Stock Eliminator under Camshaft/Lifters makes no mention of changing lifter diameter. Therefore it is illegal to do so.
Larry Merk
Larry Merk is offline   Reply With Quote
Old 01-23-2025, 01:19 PM   #44
MR DERBY CITY
Liked 7,941 Times in 1,520 Posts
Originally Posted by 1320racer View Post
Unwritten rules ain?t rules!
Hey Azzhole, I have asked you very kindly to refrain from commenting on my posts, AND I am not a very KIND person. I do not give 2 Shyts about you, your opinion OR your (. ). car……MJ Quinn
Old 01-23-2025, 01:24 PM   #45
MR DERBY CITY
Ok , so now we are back to only 2 sexes …..just like oversized lifters in stock eliminator , it does not affect me ….
Old 01-23-2025, 01:51 PM   #46
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 225 Times in 96 Posts
Considering how the rule is worded, could it be argued that an increase in lifter diameter is not a "performance-related modification"? As in, the modification should increase strength/reliability, but not performance.
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 01-23-2025, 02:20 PM   #47
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
Remember max velocity is limited by lifter diameter. So a larger lifter diameter lets you use a cam with a greater max velocity. There is a performance increase in doing that.
PS If you look in the Comp Cams Master Lobe List you will see that they have a number of lobe profiles that only will work with a .904" lifter.
Stan
Old 01-23-2025, 07:55 PM   #48
For anyone who thinks it is okay, or thinks it is a "gray area", people have been DQ'd and suspended for it.
Oh, just write Glendora and try to get a letter on official letter head accepting/allowing it.
Funny thing is, if you don't have the cam lobes designed for the bigger lifters, you're not gaining anything, you're just illegal for no reason or advantage. There are probably some lobes out there, but are they even the lobes you'd actually need, and are they even modern designs that are fast?
Old 01-24-2025, 08:43 AM   #49
Mad Manz
Thanks for the replies. I think I will staying with the .842 dia lifter. Im just making sure i'm totally legal.
As far as lifters themselves what are the best tool steel solid lifters out there?
Mad Manz is offline   Reply With Quote
Old 01-24-2025, 08:47 AM   #50
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
PPPC
