Old 01-14-2025, 12:15 PM   #31
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Default Re: Lifters In Stock Eliminator
Originally Posted by GUMP View Post
I have a friend that I believe builds pretty good stuff post photos on Facebook of worn out flat tappet lifters and cam lobes that he encountered during break-in. I have read a lot about this of late. Is it really time to allow rollers for all combinations in stock due to inferior parts? Or, are the cams victim to other factors related to the valve spring and solid lifter rule changes?
To be clear, I have no current dog in this hunt. Everything that I own and am currently working on uses rollers.
OH NO, we wouldn't want to change an obsolete rule, would we? OH, don't worry about me. I wouldn't run another flat motor if it was rated at 1/2 hp.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 01-14-2025, 12:39 PM   #32
Stan Weiss
Stan Weiss's Avatar
Liked 734 Times in 385 Posts
I don't have a dog in this fight. But it is just the results of NHRA not following their rules and then allowing rules change after rules change. If back in the beginning they had done like the SCCA you wouldn't have all of these problems.
Stan
PS I know it has been going on for a very long time. 50 years ago we were running a Lunati stocker cam in a '67 Z28.
The Chevy 3030 data is from a Cam Dr the Lunati data is from me with a degree wheel and dial indicator on a used cam.
ID:	71897   Click image for larger version
ID:	71898   Click image for larger version
Old 01-14-2025, 03:09 PM   #33
Gary Smith
Gary Smith's Avatar
Liked 132 Times in 30 Posts
Anyone use Hylift Johnson (Topline)? We sell them under the Erson brand, used on cams with springs @ 120 seat / 300# over the nose and haven't heard of any failures (knock on wood). Precision Products is probably the best, but I would think HJ Toplines are decent for less money.
Gary Smith
"another broke racer spectating"
Gary Smith is offline   Reply With Quote
Old 01-23-2025, 09:10 AM   #34
Mad Manz
Sorry in advance but I am new to the stocker stuff.
AS for lifters in Chevy's 396/325hp to be exact the rule book says you can install lifter bore bushings.
My question is when I do this can I put the .904dia lifters in or do I have to stay with the GM .842 dia lifter
Mad Manz is offline   Reply With Quote
Old 01-23-2025, 09:43 AM   #35
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Have to stay .842
Old 01-23-2025, 10:02 AM   #36
Rick J
Liked 73 Times in 37 Posts
Originally Posted by Mike Taylor 3601 View Post
Have to stay .842
Where does it say that in the rulebook?
Rick J is offline   Reply With Quote
Old 01-23-2025, 12:00 PM   #37
MR DERBY CITY
Liked 8,115 Times in 1,531 Posts
It is not in the rule book, it is in the UNWRITTEN rule book. Mike Taylor is correct. If you know…..you know.
Old 01-23-2025, 12:15 PM   #38
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Unwritten rules ain?t rules!
Old 01-23-2025, 01:02 PM   #39
Rick J
It is not in the rule book, it is in the UNWRITTEN rule book. Mike Taylor is correct. If you know?..you know.
Well, oversized lifters are in NHRA Stock Eliminator, just so you know.
Old 01-23-2025, 01:03 PM   #40
Liked 1,893 Times in 423 Posts
You can. But if you get torn down, you're getting a DQ, and probably a fine, as well as some time off.
I was actually just discussing this yesterday, with a very high ranking NHRA tech person.
In Stock Eliminator, the OE lifter diameter MUST be retained.
