Old 12-09-2024, 11:08 PM   #1
chopperloco
chopperloco's Avatar
Liked 82 Times in 23 Posts
Default Re: 1966 Chevy ll clutch linkage help..
Originally Posted by Dirk Olson View Post
Unless you are using a Chevy11 block you need to modify the bell crank the get the geometry right. If you are using a non Chevy11 block you will need to make a plate for the pivot ball and start from there. heims are always better but a little more work. Good Luck
I do have the relocation bracket for the non Chevy ll block
chopperloco is offline   Reply With Quote
