Old 04-19-2024, 07:32 PM   #1
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Engine assembly bench or engine stand
Bob Glidden never use an engine stand.
The story I remember about Glidden not using an engine stand was that it pulled the two rear cylinders out of round.There may be some merit to it. That said, I’ve always used an engine stand.
Old 04-19-2024, 08:09 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
If it pulled them out of shape which is very possible with a stock Ford block, it should still go back to where it was when taken off the stand. A cylinder will go out of shapre with the plate or head off but go back in shape when they are put back on.
Old 04-19-2024, 08:56 PM   #3
Mark Ugrich
“ should go back” might be the key phrase there.I’d think they would have some resiliency but how much? I don’t know if Glidden sleeved any of his blocks,but if he did that would change things also.
Old 04-19-2024, 09:23 PM   #4
Liked 1,922 Times in 432 Posts
I've always used a stand. At least to finish. I have put the cam and crank in on a table, some times. But always finished on a stand.
Old 04-20-2024, 02:30 AM   #5
Al Reed
Liked 2 Times in 2 Posts
This is the answer, holds both ends of the engine, so no rear cylinder bore issues: https://www.summitracing.com/parts/otc-1735b
Al Reed is offline   Reply With Quote
Old 04-20-2024, 07:29 AM   #6
Billy Nees
Liked 7,887 Times in 1,753 Posts
Ya know, if this is really such an issue, then shouldn't the engine be assembled with a transmission case bolted to it and sitting in the car, on the mounts?
Billy Nees 1188 STK, SS
Old 04-20-2024, 07:49 AM   #7
Liked 10,969 Times in 2,261 Posts
That’s some good thoughts Billy.
It would be fun to build one on the bench and dyno the engine. Take off of dyno remove heads and pan, loosen caps on mains and rods install on stand and reassemble then dyno.
With the block I run you can breathe on it and it changes.
