Liked 1,104 Times in 302 Posts
Like Larry said, at least on Fords, the manual brake cars came with a different brake pedal, with a pivot for the master cylinder pushrod closer to the pivot for the pedal itself, for more mechanical advantage. Again, with my Fords, manual master cylinders a re usually a smaller bore, like 7/8" or 15/16" diameter, compared to over 1" for a power brake application.
Liked 883 Times in 237 Posts
As was mentioned pedal ratio is critical .If the car originally had power brakes the ratio was only around 4 to 1 ,a ratio of 6 to 1 is considered ideal . also ,If you are only using discs on the front and retained the drums on the rear ,a master cylinder with a smaller bore will help.
On a disc /drum car I usually use a 1 3/32 bore master cylinder which wit the 6 to 1 pedal usually will yield around 1000 psi with reasonable pedal pressure.
Liked 253 Times in 95 Posts
On my ‘71 Duster, I used an aluminum master cylinder that came on the Volare/Aspens. I have Strange fronts and stock 10” rear drums and factory proportioning valve also from Volare/Aspen. Never a problem stopping or holding the car. You could have a bad brake hose or a stuck caliper. Make sure too use the braided front brake hoses.
George Mirza D/SA 1236 ‘71 Duster 340 |
#4 | |
Liked 84 Times in 21 Posts
Liked 2,486 Times in 697 Posts
All our A bodies have 7/8 or 15/16 Cylinders
The large one would not let my elder legs hold the two step or stop quickly. We try for 7:1 and sometimes redrill the brake petal itself and relocate the master if need on several of our different stockers. Particularly on the two Aspens F Body cars. You will figure it out. PM me if needed.
The rubber fatigues and expands producing
a spongy petal. At a minimum replace the stock lines every few years.
thanks for the info does anyone have the part number for the volarie style master cylinder? would i be better off going back to the stock master cylinder? also i was told to delete the proporting valve all together was that a bad idea?
Liked 10,755 Times in 2,236 Posts
I race the Cuda without the valve.
#9 | |
This is a dumb question, but do you have the lines hooked up to the proper ports on the master cylinder? Front to the rear and rear to the front. Did the car have a power booster in it originally? Like someone else said in an earlier reply, the pedal ratio could be the issue.
thanks for all the info parts are ordered
