Old 01-20-2023, 09:36 AM   #11
Doug Hoven
Liked 867 Times in 165 Posts
Default Re: No Blinders
When are we going to do something about the "data loggers can't be hooked to the ignition box" rule? Or how about the "no driveshaft sensors" rule?
One problem I foresee with trying to enforce this, is what are you going to do with all of the EFI guys that use their ECU to control their MSD ignition. Specifically, one of the more, relatively speaking, "dumb" MSD boxes such as a 6al, 7al-1,2,etc. I understand the things that can be done if someone were to be using a GRID, but these other boxes have no internal hardware of their own to do any sort of "witchcraft" during a run. It would be relatively straight forward to police datalogging with a racepak. If the sd card isn't in it, and no computer is plugged in to the COM port, no data is able to be recorded. EFI however stores data logs within the ECU, so that could be a tricky one.
1189 F/SA
Defunzalo Racing Enterprises
