Old 12-22-2022, 06:18 PM   #38
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Default Re: 65-85 under.
Ya can put any of the B-O-P Racers on that list.
When is the last time a B-O-P Racer got a bigger cam or a change in the weight of the rotating assy.?
Unless it's a misprint,the B of the B-O-P racers have 10.5 compression pistons in 1971,1972,1973 on the engine blueprint specs.
I always thought the 1971 engines started the era of low compression pistons and unleaded fuel.But I might be wrong,as I was only 5 or 6 years old at the time.I know the O got low compression pistons.
