Old 12-18-2022, 11:05 AM   #1
Mike Gray
Mike Gray's Avatar
Liked 711 Times in 205 Posts
Default Re: NHRA hp updates
If you can’t run at least -.650 under at a race it will have zero affect on the average. It will be like you were never at the race according to the AHFS.
Oh, okay I’m catching on to the new AHFS if I run BETWEEN .650 - .850 under they will like me and over .850 under and they will send me hate mail. Do I understand this correctly that my combo in B can affect other cars from AA - C because it’s in the same engine family even though the engine specs may be different, like different heads and valve sizes? I must have skimmed over the paragraph below too quickly.
“1st screening: The average for all vehicles running the particular engine family combination being reviewed is included in this screening. The review process will average runs in ALL classes TOGETHER with the same transmission type & the same body platform.”
Mike 7570 A/SA
Old 12-18-2022, 01:45 PM   #2
Tom Meyer
Liked 354 Times in 120 Posts
Assuming transmission means auto or manual? I was going to sort out my SS combo with my trusty PG vers a three speed that some say are 15 quicker. But I still could take the hp hit. Now what about wagons, is a chevy II wagon going to be the same platform as a 2dr ht? Is the malibu wagon the same as 2 door car. Tom
Tom Meyer 5240 SS Stock ???
Old 12-18-2022, 01:50 PM   #3
Billy Nees
Liked 7,925 Times in 1,760 Posts
Tom, I'm pretty sure that they go by wheelbase. If the hardtop and wagon have the same wheelbase then they're considered the same.
Billy Nees 1188 STK, SS
Old 12-21-2022, 02:51 PM   #4
Your combo cannot affect anything other than that same engine combo. If your combo has different heads, valve sizes, etc, then it doesn't affect combos that don't have the same specs. So, if your combo has 2.07"/1.725" valves and oval port heads, it will not affect a combo with 2.195" and 1.725" valves and rectangle ports.
Old 12-21-2022, 07:46 PM   #5
Bob Shaw
Liked 323 Times in 63 Posts
That's the way they say it works. For the 4.3 Chevy tbi engines they factor flat tappet cams, roller tappet cams, 108 wheelbase, 117 wheelbase, 430 lift cams, stock lift cams, cars or trucks together. All are considered the same engine family and body style.
Bob Shaw V/SA 515
Bob Shaw is offline   Reply With Quote
Old 12-22-2022, 02:16 AM   #6
Mike Gray
Mike Gray's Avatar
Okay, makes more sense. Why couldn’t they just say running the same engine specs rather than “engine family”.
Mike 7570 A/SA
Old 12-23-2022, 10:49 PM   #7
Terry Cain
Terry Cain's Avatar
Liked 232 Times in 108 Posts
They wouldn't do that. They paid a law firm to write the wording.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 12-23-2022, 11:18 PM   #8
Mike Gray
Mike Gray's Avatar
The FE engine family is confusing enough with all the different variations. There are numerous combinations that could be in the same class. Now I see how this could help with the average for each because hardly any two 428 cars are running the EXACT same combinations.
Mike 7570 A/SA
Old 12-28-2022, 04:04 PM   #9
Bernhard
What effect would bringing back the factory valve spring rule have?
Would this not simplify tech and negate some of the advantage found in cylinder head and intake advancement?
Bernhard is offline   Reply With Quote
