Old 05-17-2022, 10:38 PM   #22
e vassar
Liked 278 Times in 110 Posts
Default Re: poor excuse for tech at NHRA National
Originally Posted by Crew Chief View Post
Questions...Did the tower notify tech immediately that Hawk had made a 9 second run? Did the tower know that Hawk did not have safety equipment for a 9 second run therefore immediately notifying tech? Did tech immediately confront Hawk about the 9 second run without the proper safety equipment in use? Did Hawk's opponent immediately stop at the scales and notify tech that the proper safety equipment was not being used? Do the tech cards when entering online have built in limitations as to how quick a car can run based on safety equipment declared by the racer? Would the old way of "hands on pre-race tech" have warned Hawk he was not allowed to go quicker than 10.00 due to lack of proper safety equipment?
Have you filled out an online tech card lately?
There are questions and answer spaces there pertaining to everything from head casting numbers to neck collars, parachutes, window nets etc. And a disclaimer that says I know what my car/class requires. and I'm good. If a spot check determines otherwise...well then you got some splainen to do!
