Liked 231 Times in 107 Posts
Why are (some not all) stockers still running flat tappet lifters when a motor with flat tappets ain't been made in 20 years and a set of tool steel lifters is $2100, 4-6 months back order . Guess my old head just don't see the reasoning or the difference between lifters and rockers. .
#2 | |
Liked 185 Times in 56 Posts
John Ancona 717 STK / SS |
Liked 998 Times in 276 Posts
Most don't want solid roller cams in stock, just go back and read posts about it in the past. Opening up that box will get you one more step closer to making a stocker engine a super stock engine with a lift rule.
Duane Hoven 1342 SS/GT |
#4 | |
Liked 1,104 Times in 302 Posts
Then put the rules back ,and most will wine about that , in case you haven't noticed stock is already Super Stock ,the lifters will not change fact that stock has gotten way out of hand ,you stated Open up that box will get one more step closer to making a super Stock engine with a lift rule , well, you and others better look again if we are only the lift rule away if we change the lifters what about the other enhancements to stock over the years to get us all to this point ,You freely use the word most ,would they be the guy's that are cheating spending lot's of money to cheat are they the ones that you call most ! The point you ,and others are missing ,and it is still the same as it was back in 2016, and even before that the old cars are at a disadvantage you ,and others may just want to see them disappear while you drive a late model race car with roller lifters ,and have others that can't aford to keep dealing with the lifter problem !
Liked 7,756 Times in 1,741 Posts
Ya piks yer kombo and ya pays yer dooz.
If you want a roller lifter combo with EFI then that's where you start.
Maybe we need a poll because MOST (from my outlook with all the new motors available) are already running solid rollers. They wouldn't need to vote. It looks to me like the only ones not running them are the cars from 60-early 80's. At the rate of $2100 a set and 6 months wait time for tool steel lifters they can lower the entry to 30 and 95% will be roller motors. If I have to qualify for a event spot against a non-vin, state of the art, factory made race car at least make it fair for the old flat tappet cars.
#8 | |
Here's a "fair" way to make this work without affecting anyone else, why don't you go and buy a "non-vin,state of the art, factory made race car"! It's thinking like THIS that has S/SS in the screwed up state that it's in and why there needs to be some re-thinking and some back-tracking of some of the rules by NHRA and Tech.
Liked 455 Times in 147 Posts
Just like after market heads, if you car did not come with Roller lifters, if you want to run them, add an additional 5 hp to your
Combo. NHRA should have implemented other HP adjustments for several other non OEM approved engine parts. Would of leveled the playing field in Stock. Steve Teeter Stk/SS 620 |
#10 | |
