Liked 633 Times in 88 Posts
AHFS will never work with its current leadership. Now if Lonnie Grimm cleans house/ eliminates the problem, then it might have a chance but let’s face it AHFS has had the same problems 10-15 plus years now.
1. You can run -1.10 at an event and go to the next event and make 2 passes at -.55 to bring your average back to under-.80 making it safe from HP. This window to lower your combo average are passes of -.85 to -.35. This window is way to big. I mean how can some make an argument that one weekend a guy runs -1.00 and the next weekend there making runs at below -.60. to pull the average down. There is no logic to this window. Personally, if a combo can run -1.00 then no runs under -.65 should count in lowering the class average 2. I Think the most important thing that will help AHFS work and put NEEDED performance back in the SS/STK class is going to a 48 or 64 car field at ALL National events (But INDY). Let’s face it the national event quotes are not going back to 80 plus cars per class at most national events so let’s just meet in the middle make all the quotes 70 cars per stk and ss. This will make guys step on there cars a little more frequently. I personal would like to see 48 car national event fields with around 60-65 car quotes. This would reward the #1 with the potential semi final bye into the final. I would leave points meet at 128 car fields and national open at all run field. This would create a kind of steppingstone affect for the class depend on you combos performance. This would also eliminate the 105 points Issue for winning a 6 or 7 round national event (East Coast VS West Coast) if all the National events were a 6 round max to win. 3. All runs of over -1.00 should have a min carb/TB check, casting # check and a PG if time permitting.
Charley Downing 3548 STK Last edited by Charley Downing; 10-31-2021 at 02:25 PM. |
