Liked 544 Times in 213 Posts
I've been reading this thread and wondered why no one mentioned detonation as being a possible issue.
It can show up in rod bearings.... Usually the shells just fall out....and might have some odd looking wear marks....
#2 | |
Liked 920 Times in 259 Posts
Fly poop on spark plugs? Fuel change? Verify timing and TDC marks? Try another known good timing light? Just reaching here. |
Liked 7,732 Times in 1,739 Posts
or cam change too!
Liked 10,712 Times in 2,230 Posts
First noticed it when we started getting close to the 590 hp number. Damper is on TDC, fuel seems to make no difference c11, c12, c10, renegade 116. cam changed made no difference.
If the engine is apart and obviously it is....
Look at the ring lands and the tops of the pistons for any oddball signs that usually indicate detonation. Pecker tracks on pistons, or on the sides of the pistons above the rings. Ring lands beat up.... If all is clean then you can rule it out.... It's not likely but I thought I'd throw it out there.
Liked 2,725 Times in 961 Posts
Just thinking out of the box, how old is the Harmonic Balancer?
At least 6 to 8 years old. Last time it was down I had crank checked for balance it was ok
