Old 07-25-2021, 09:45 AM   #1
fordteacherguy
Liked 160 Times in 51 Posts
Default Re: Moving from bracket to Stock Eliminator
Devin,
Come over and see me and Seaberg next time you are at Bremerton. There is s no mystery to make a Ford run. Look up a good combo, plan to spend money in the right places and don't compromise on quality of machine work.
I know all of the sources in our area... See you at the races!
Brian Thompson
NHRA Stock / Super Stock
Class P/SA 6665 SS/MA 6665
fordteacherguy is offline   Reply With Quote
Old 07-25-2021, 10:32 AM   #2
Dave Gantz
Liked 251 Times in 125 Posts
That's the part he doesn't seem to want to do. I hope he changes his mind.
Old 07-25-2021, 09:00 PM   #3
jmantle
Liked 172 Times in 81 Posts
Devin,
Good place to start, to good die hard Ford guys.
Jim Mantle V/SA 6632
Jim Mantle U/V/SA 6632
jmantle is offline   Reply With Quote
Old 07-26-2021, 10:24 AM   #4
Carguy49
Liked 3,015 Times in 721 Posts
Brian Thompson and Brian Seaberg are both great guys.
Their Ford knowledge is great. They can answer most anything that you might want to know, about Ford stuff and Stock Eliminator drag racing in general.
Two really great guys that are great friends also. Lots to like about these two guys. Always fun to hang with when I am at the drags.
Ron McDowell - Did Race
Old 07-26-2021, 06:27 PM   #5
Signman
Liked 269 Times in 99 Posts
Get a copy of the rule book read it and know it. Know all the underlying rules that build to Stock Eliminator and beyond. Make it work for you in place of hindering you. It's just a point of view to decide to take.
Know the Automatic Horsepower Factoring System. Period.
Study combinations and know the one you choose. Talk to others who run it or and/or know more than you. If given advice at least try it sometimes it's a process that's layered. One piece of advice builds on to the next. Generally if you ask for advice then go back for more not trying what was already given you're a tire kicker and not serious. You have to work on your car!
The most important thing is to race, get the car out there. As for performance the bottom line is simple:
The Bracket Racer. Be happy with the performance you have and race, suffer and accept the consequences of the ladder and heads up races.
The #1 Qualifier / Record Setter. Do the work and spend the money to set records and be the fastest in the country. It's not all spending money it has to be spent correctly and the associated work done the best you can and better. Be ready to chase your tale to protect the combination to keep the advantage you worked and spent for.
The Bottom Line (this is my opinion only others may vary) To be competitive in the eliminator have to be able to go a second under your index where ever you race. It forces the competition (and you) to accept hitting a AHFS trigger in a heads up (no easy HU runs against you) plus it allows you move around the ladder if you choose to play the ladder game.
Good Luck and Many Win Lights
Old 07-26-2021, 06:46 PM   #6
F677
F677's Avatar
Liked 21 Times in 6 Posts
Frank,
That's the all BS aside shot I like. I admit, I know I'm coming in as the bracket racer. My combo will not be easy, or likely to be 1 under. If it won't run .5 under I'll tear it apart and try again. Hoping for .8 to be honest. This is my "dip my toe in" start to big kid racing to see if it suits me. If it does, a more favorable (Ford) combo will follow. I hope to get to know you all soon, and you'll see that I'm no rub. If I'm in, I'm in, and I won't worry too much about the ladder.
Devin Froud
Div. 6
Roy Wa
F677 is offline   Reply With Quote
Old 07-26-2021, 10:52 PM   #7
fordteacherguy
Devin,
Looking over the 67 289 4v combo it has some good traits, +11:1 compression, heads are ok...typical small valve SBF head...making the Autolite 4300 4v work might be a challenge..small float bowl...there was a reason we called them toilet bowls in the.day...bone up on that particular carb tuning. Not a lot of stuff for that carb out there. Don't see it being a killer, but if you are determined...it looks like it could do the index...wish it had a better carb though...
Brian Thompson
Old 07-27-2021, 07:29 AM   #8
1347
1347's Avatar
Liked 1,026 Times in 281 Posts
Devin,
Devin,
You may be better off running that car in super stock with that engine, you can run the replacement aluminum head, and it will be fine with a 9" tire and a caltrac. Whether you run stock or super stock, Vern Buchanan would be the person to talk to about doing the carb.
Good luck with the project
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
