Old 01-24-2021, 10:22 AM   #26
J518
Liked 151 Times in 37 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
Originally Posted by FireSale View Post
Your starter wire looks like it's on the battery side of the cut off switch. That would leave a hot wire under the hood after the kill switch was thrown.
I'm a little confused here. Looks like two of stuff like fuel and water pump?
Remember that each of those relays has 4 terminals. You need 12 volts in, 12 volts from the switch to trip it, a ground and a wire to provide the power to the accessory.
EDIT Not two pumps, two relays. One looks like it's on the power side and one on the ground.
Yeah i think i have you confused because the symbol for a dc motor and a dc relay coil are the same. I will nomenclature them better to keep everyone from getting them mixed up
J518 is offline   Reply With Quote
