#31 |
Liked 498 Times in 235 Posts
How good are the Calvert shocks?
Jake Biermann |
#32 |
Liked 151 Times in 37 Posts
#33 |
Instead of watching it snow I decided to get some pre planning done....Here is an electrical print I made. Seems to simple, feels like I am missing alot. Let me know!
#34 |
Liked 237 Times in 126 Posts
Your starter wire looks like it's on the battery side of the cut off switch. That would leave a hot wire under the hood after the kill switch was thrown.
I'm a little confused here. Looks like two of stuff like fuel and water pump? Remember that each of those relays has 4 terminals. You need 12 volts in, 12 volts from the switch to trip it, a ground and a wire to provide the power to the accessory. EDIT Not two pumps, two relays. One looks like it's on the power side and one on the ground.
Dale Shearon 68 Mustang 6394 Last edited by FireSale; 01-23-2021 at 11:15 PM. |
#35 | |
#36 | |
Liked 721 Times in 221 Posts
#37 | |
Is your cut off switch external? If so the only way to kill power to that main distribution block is from the outside. There should be a master cut off within the drivers compartment to shut stuff down on one switch. I've used a push button 100 amp breaker - the big black things - for this. My main power now runs through a high amp continuous duty solenoid. A toggle switch activates it to apply power.
#38 |
Liked 70 Times in 31 Posts
you have a PM. thanks
#39 |
Snow slowed us down but we were able to wrap up the brakes lines this weekend.
![]() ![]() ![]() ![]() Last edited by J518; 02-01-2021 at 02:53 PM. |
#40 |
REAR
