Old 12-03-2020, 01:07 PM   #5
Glenn Briglio
Glenn Briglio's Avatar
Liked 975 Times in 311 Posts
Default Re: When to freshen our transmission
The lo/rev sprag in a 200, is a wear item ( I don't want to say weak) It could be damaged in an event such as above.
Other than that, the direct clutch can also be an item to look at.Some builders like to run a bit lower line pressure than I do in mine. This is probably an item that should be discussed with your builder..
What would you consider an acceptable line pressure? What would be too low?
