Old 09-17-2020, 09:27 PM   #11
FED 387
Liked 330 Times in 178 Posts
Default Re: carb
HSAB plugged or maybe you have the bowl gasket or metering plate gasket installed incorrectly OR you have the wrong gaskets to start with---a symptom of definitely siphoning fuel out
Old 09-18-2020, 08:21 AM   #12
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: carb
Originally Posted by Jim Hanig View Post
No the fuel only comes out when the engine is running, some one suggested check the air bleeds . I did that and that seemed to fix it. Thank for the help.
Was one or more of the air bleeds plugged up ?
Old 09-18-2020, 05:53 PM   #13
NORMAN BARNARD
Liked 2 Times in 2 Posts
Default Re: carb
Question: Why would 2 seperate carburetors do the same thing
and the solution be a "plug'd" hi-speed air corrector be the answer?
Technically doesn't make sense unless jim lives in the desert an he doesn't.....
NORMAN BARNARD is offline   Reply With Quote
Old 09-20-2020, 12:17 PM   #14
GTX5877
Liked 20 Times in 9 Posts
Default Re: carb
Run leak down test on engine. Bet you'll find the problem
GTX5877 is offline   Reply With Quote
Old 09-20-2020, 05:20 PM   #15
FED 387
Default Re: carb
Not sure if you wrote "its solved" but you can run the engine up to about 2500RPM and put a gloved hand or towel over the carb top when the engine has almost died remove your hand or the towel and let the RPM come back up---do this 2-3 times and see if it clears up ---what you are doing is going from vacuum to siphoning and jostling any particles that may been the bleeds or the idle passages--kinda self cleaning or sloshing process by going back and forth
