Old 09-14-2020, 01:51 PM   #1
Race Clean
Liked 129 Times in 53 Posts
Default Re: Broken Front Wheel Studs
Originally Posted by Shadylane View Post
Nope, but the MW’s I ordered have a head.
I think you got your solution right there,I have sheared a Moser stud for no real reason, looked like they had cut threads instead of rolled,I decided to go away from Moser totally at that point and got axles,spool,bolts and misc. stuff from M/W,just put the stuff side by side and you will never look back!
Stop global whining
Race Clean is offline   Reply With Quote
Old 09-14-2020, 07:43 PM   #2
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
I agree the Moser studs look like low grade stuff. I have Moser axles and spool also. So far so good on them. My car is a low hp U/S car so I thought the stuff would hold up.
Kelly Lane Stk4991
Shadylane is offline   Reply With Quote
Old 09-15-2020, 07:40 AM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
A headless stud is dependent on the threaded fit between stud and hub for alignment. Lacking a head, the stud is going to pivot in the hub thread and be loaded/twisted along it's length as the wheel nut is torqued. Not hard to imagine what happens then. -Al
"That'll never work....."
Old 09-15-2020, 01:06 PM   #4
r429469
Liked 40 Times in 26 Posts
I have had this happen, a spacer between the wheel and the hub caused the studs to brake. I'm not sure from the pictures but, is there some kind of spacer on your hubs?
r429469 is offline   Reply With Quote
Old 09-15-2020, 01:57 PM   #5
CMcAllister
Liked 920 Times in 259 Posts
Granted I don't pay attention to what every company offers outside of my preferred sources, but I have never seen a headless stud offered for this application outside of the 5/8 drive studs using jamnuts of rear axles. Nor would I consider using them.
I don't want to bash anyone who supports racing, but that's a head scratcher.
Old 09-15-2020, 05:43 PM   #6
65signet
Liked 44 Times in 21 Posts
I bought some Moser studs for my rear axels, and i was not impressed with the quality.
Steven Barnes
Stock 704 N/SA
65signet is online now   Reply With Quote
Old 10-10-2020, 08:35 PM   #7
Capri
Liked 27 Times in 14 Posts
The center bore on the wheel is something that was a problem when going to aftermarket brakes. Depending on the wheel brand, either the wheel had to be machined to accept the hub, or you had to run a spacer under the rotor hat. Even though the wheel would appear to sit flush on the hub, it would be off and start to bend the stud if you forced it to tighten up. This was something more specific to the 4 lug wheels compared to any of the 5 lug. So then even at a torque spec of 50lbs, it wouldnt torque correctly but it would tighten up. Would cause a pretty good vibration in the front end rolling along that you could chase for a bit.
Capri is offline   Reply With Quote
