Old 04-14-2020, 01:33 PM   #5
Andy Friar
Andy Friar's Avatar
Liked 226 Times in 76 Posts
Default Re: Stock Eliminator Cylinder Heads
Originally Posted by Jim Hanig View Post
my experience has been that if you don't do what the fast guys are doing your not going to be nearly as fast. The rules are pretty gray as to what you can do to the heads and intake. No grind marks and rite cc in the runners your good to go.Unless you run into Westly or Wayne then you mite have a problem, of course the cost of the heads ,manifold is now in the 5500 dollar range. Then there are some combo that are still soft,You just need to pick the rite one and get your check book out. Or be prepared for a uphill battle, ask anyone who has been doing it for many years.
What STK combo(s) are the heads and manifold $5500? I am assuming at that cost they are built up and installed, correct?
Andy Friar
Andy Friar is offline   Reply With Quote
