Old 02-03-2020, 09:37 PM   #32
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Drag radial life/ max passes ?
I 60' about the same as you, and I've always been a top hole guy. It puts more downward force on the spring.
I've also never tried to leave at nearly that high RPM. If I'm hitting the top bulb I'm at 3400, and the bottom I'm tuning my light with RPM and usually end up at 2900 or 3000.
I could see the high RPM being a big part of your issue, or at least not helping.
S/ST 51
S/C 53
