Old 02-03-2020, 05:01 PM   #30
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Default Re: Drag radial life/ max passes ?
Originally Posted by Tex013 View Post
Lenny , Ed
thanks for the response . I have only ever run radials on the Plymouth , bought it in 2007 . Never had this issue with the MT PBR only this Hoosier style . Is there some fine adjustment with shocks left ,yes . Enough to eliminate this , probably not .
Will normally lift front wheels 6-8" , rear will separate / lift 3-4". Has caltracs . So it is hitting tyre hard , pics always show some tyre wrap .
Tex
What RPM is your 2-step at, and which front hole is the Caltrac bar in?
S/ST 51
S/C 53
