Old 01-30-2020, 05:27 PM   #1
nhramnl
Liked 358 Times in 83 Posts
Default Re: NHRA 2020 Rule Amendment SS Intakes???
Originally Posted by Joey Bohannon View Post
Bert knows exactly what he is talking about! If they cc without the spacer plate there is a ton to gain. And if there wasn't gains to be had in port volume, then why do they make'm. Air speed can still be retained with more volume.
Joey and Bert are correct. This is EXACTLY what Westcott did to build the monsters he and his dad ran in SS/AH.
Old 01-30-2020, 10:01 PM   #2
l88427
Liked 17 Times in 8 Posts
Don't think so,Wescotts heads don't use plates and still retain the valve cover bolt holes...
l88427 is offline   Reply With Quote
Old 01-30-2020, 05:10 PM   #3
bert powell
Liked 34 Times in 12 Posts
Bert,
Do you even know what you are talking about?
Gain 50 to 60 cc's when the rules allow you to port, epoxy and epoxy the cylinder heads?
If the port volume is measured without the spacer, you get to add all the spacer volume into the port. Very simple to understand. Make the rule that the port volume is measured with the spacer and I bet you wont see anymore of them.
bert powell is offline   Reply With Quote
Old 01-30-2020, 05:15 PM   #4
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Exactly how do you do that with a sheet metal intake (and there are no plates) ?
Jeff Niceswanger 3740 SS
Old 01-30-2020, 06:02 PM   #5
bert powell
You are exactly right Jeff, sheet metal intake would cover it up. So the rule of not cutting into the valve cover bolt and angle of +/-2 degrees would put some parameters to the rule.
As for it being legal per the rulebook, the no external modifications wording makes it illegal. Also, isn't there a sentence somewhere in rulebook that if it doesn't say you can do it, then you can't? Not sure about that but recall something like it.
I looked at a bbc head last night and roughly calculated the 50-60cc number using 1.75"x2"x1" but the port is oval not rectangular. So it would not be that big but bet it is 30-40cc. The advantage would definitely be bigger for bbc verses sbc.
Old 01-30-2020, 09:02 PM   #6
SSDiv6
The spacer is just an extension of the intake runner. Just adding more volume to the intake tract does not make more power. As Jeff Niceswanger stated, you can do the same with the proper sheet metal or billet intake or even by welding a cast intake.
Old 01-30-2020, 10:03 PM   #7
l88427
This!
