Old 12-28-2019, 03:54 PM   #18
jamie2370
Liked 239 Times in 90 Posts
Default Re: Out of the loop in superstock....
Originally Posted by Kevin Panzino View Post
So with that logic, and just keeping it related to the transmission: We all have to remove our straight-cut/different than OEM ratio gearsets, take out our roller bearings and go back to bushings, remove our low volume front pump and put a stock one back on, make sure we run the correct number of clutches and steels that the OEM trans had, remove the aluminum drums and put the cast iron OEM ones back in etc etc etc ?
No, because all those parts are replacement for original parts in the trans. A fluid dump valve is not and never has been a part of a transmission. Its new technology. As far as i know, only a th400 has been built right now with the technology. I could be wrong. It also mounts externally so it would be fairly easy to police.
jamie2370 is offline   Reply With Quote
