Old 12-16-2019, 11:37 AM   #14
HawkBrosMav
Liked 302 Times in 73 Posts
Default Re: 68 ford cylinder head flow numbers
Originally Posted by HP HUNTER View Post
Heres the flow sheets on Kips 289 heads. Tested on a SF 600 sealed 4.00 bore @ 28 inches. I also have a (289) flow test from another well know Super Stock head porter as well peaking @ 215 CFM.
I will tell you that my brother worked a lot with Kip when putting together his 289 combo a few years back. Straight from Kip's mouth his quickest ET 289 heads only flowed 195ish.. I can't remember at what lift he said that was at, but he said he had a lot of heads he did that flowed bigger numbers but none we as fast as that particular set.. there is WAY more to having a better head that straight flow numbers. It's an easy barometer to know if your in the ball game but just because you can get a head to peak out 20 cfm higher at it's best doesn't make it a better head that the lower flow one...
