Old 11-14-2019, 12:06 PM   #1
Jared Jordan
Liked 537 Times in 119 Posts
Send a message via AIM to Jared Jordan
Default Re: Current rules you’d like to see enforced
Originally Posted by Daran Summerton View Post
Why do automatic stockers have buttons on the wheel?
Some guys have line-loc's there. My car was that way when we got it in 2017, but I've never driven one with it anywhere other than on the shifter so changed it before I ever drove it.
Jared Jordan
9 B/SA
2024 Jeg's D7 All Star - Stock
Jared Jordan is offline   Reply With Quote
Old 11-14-2019, 12:41 PM   #2
novassdude
Liked 136 Times in 49 Posts
As far as towing to the lanes. I think the fair rule would be that the car that is pitted the farthest away should be allowed to tow to there opponents pit and both cars need to be driven to the lanes from there. Then there is no advantage to the person with the up-close pit spot.
novassdude is offline   Reply With Quote
Old 11-14-2019, 01:17 PM   #3
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
With live feeds displaying RTs could this be radioed to driver?
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 11-14-2019, 01:20 PM   #4
Daran Summerton
Should sportsman classes have radios?
72 cutlass
Old 11-15-2019, 01:12 AM   #5
GUMP
Liked 2,354 Times in 554 Posts
Since so many cars were available without radios, I would say no.
GUMP is online now   Reply With Quote
Old 11-15-2019, 12:29 PM   #6
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
I still don’t understand the comment about the lt1 and L98 throttle bodies?
Old 11-15-2019, 03:16 PM   #7
cmracing
Liked 62 Times in 29 Posts
The entire L98 induction system was designed for the 305. If you have a 350 it will most likely make more power with a larger TB, and certainly would make more power with a ported base manifold which to my knowledge does not have any specs on it, except you aren't supposed to modify it......... There is a lot of junk in the way inside the plenum, but it would be damn obvious to remove any of it if someone knew what to look for. Bolting a 58mm TB on a stock plenum will do nothing, the plenum opening is sized for the stock TB.
Not sure about the plenum opening on the LT1.
cmracing is offline   Reply With Quote
Old 11-16-2019, 05:30 PM   #8
The Hawk
The Hawk's Avatar
Liked 249 Times in 109 Posts
I think Daran meant 2 way radios between the driver and crew on the starting line...
Lane Weber
Old 11-17-2019, 11:19 AM   #9
Billy Nees
Liked 7,754 Times in 1,741 Posts
Ya mean that he's not talking about my AM/FM? It's factory! How about my under-the-dash CB? Can I keep that?
Billy Nees 1188 STK, SS
Old 11-14-2019, 05:02 PM   #10
Tony Fagnilli
Liked 205 Times in 44 Posts
I like that, good idea
Tony Fagnilli is offline   Reply With Quote
