Old 09-04-2018, 02:30 PM   #11
Mike Fuller
Liked 198 Times in 79 Posts
Default Re: Now that Indy is over....
Well Jim first let me tell you a little about myself. I started racing Stock in 1983. It took me a full season before I could run the index in my 1969 B/SA Camaro. I did most of my own machining and all of my own assembly. Holbrook Racing did all the things that I did not have the equipment to do. In 1991 I set the record in C/SA at the Rockingham Invitational. After I made the backup pass and was weighed and fuel checked the national event tech director told me to pull the car over by the scales and to bring my tools so they could observe me disassemble the motor. In 1992 I was the TRW (Jegs now) division 3 Stock representative. The race was held at National Trails outside of Columbus Ohio. After the first qualifying pass we were sealed up ( Carb to intake. Intake to cylinder head. #4 plug sealed to the head.) We had to be torn the next day at noon in the middle of the pits by the scales. If any of the seals were broken we would be DQed. In 1993 after winning C/SA class at the Southern Nationals I was selected again for tear down and had to put the car in a designated area and Ron Cook was assigned to observe me.during the entire process. BTW Tom Rhoda who helped me tear down won that race with a 427 that I built for him. At the Spring Nationals that year I won the Spring Nationals with a.000 light and also won B/SA class at Indy that same year.
You on the other hand you got to show up for inspection an hour late with the intake and throttle body off the motor. There was no trans in your car. If you want to question or deny this I have a number of witness that will back me up. I felt very violated by this. During the inspection I had to go to my trailer for some tools. I fell off my Spree and had to go to the first aid station for some minor repair. On my way back from there I came across Bruce B and told him how you showed up. His response was " That's Bull$hit!" He then apologized to me and said that he was very busy and was unable to supervise the situation.
We protested Don's car because you have caused both combination's (2013 and 2014) to be hit with horsepower without the usual teardown. In Division 3 if a car goes quick enough for that combination to get HP Traves Miller will conducted a technical inspection. I as well as all of my fellow division 3 stock and super stock racers will back me up on this.
One last note about this protest. I was not the only one to put up the required money for this. In fact stock racers from other divisions contributed.
Enjoy your day
Mike
Mike Fuller 396 STK
3961 SS
