#1 | |
Liked 586 Times in 162 Posts
Liked 251 Times in 125 Posts
Do you use a practice tree? I found that it helped me narrow down the range of the lights I was cutting. Then I was able to zero in on when to leave.
Of course, if they eliminated reaction time, none of this would matter. :-) |
Liked 101 Times in 52 Posts
So then you prestage bump in and check brake pressure then look at the tree and get on the two step? I don’t mean to sound synical, just want to make sure of the process and if this would help me
#5 | |
Liked 502 Times in 130 Posts
Everyones staging method is different, I don't look at the gauge, I listen for the two step if I am running it. My dakota fuel injected two step process is totally different than the footbrake gremlin(I don't run the pressure switch two step on it, just a gauge) Two step is just faster for some cars/trucks. I like footbraking more. Even better is a stick, now that is where the fun factor really comes in, lots of variables you can tweak to adjust RT, but don't ask me specifics, I'm a novice. Eric
Eric Merryfield 1883 STK |
