Old 11-26-2017, 06:15 PM   #1
Timetraveler
Liked 12 Times in 6 Posts
Default Re: 1964 Chevy ll 283/220 hp
If your running stock the newer NHRA rules have made it a little easer to be competitive with this combination. Roller rockers, beehive springs and a three speed transmission helps.
Timetraveler is offline   Reply With Quote
Old 11-26-2017, 06:39 PM   #2
Tom Meyer
Liked 354 Times in 120 Posts
51 5911 R/SA Bobby Devine, Cozad NE, '64 Chevy Nova 13.458 14.05 -0.592
Bobby runs a 2bl carb, no roll bar needed. Ask anybody in Div 5 Bobby has a lot of fun in his car .Monty Jones preps this car and could enlighten you what it would take to run one. Tom
Tom Meyer 5240 SS Stock ???
Old 11-26-2017, 06:41 PM   #3
james schaechter
Liked 1,434 Times in 299 Posts
Jim, the 283 is fun, but won’t be as good as the 327 250 hp combo. If you ran G stick it might be fun, but there are a lot of combos that are better
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 11-26-2017, 09:16 PM   #4
Liked 5,124 Times in 1,953 Posts
1964 was a big year for change in the Chevy II line.
Bigger brakes, spindles, 5 lug wheels, and the Salisbury type 8.2 rear, but not the 327 until 1965.
Of course , you can make a 64 hard top car into a 65, but not the post car , ...very easily anyway.
That being said , I do like the 65 250 hp stick car. If a 66 Q-jet car can run deep into the 10's, a 4GC should run 11 flat anyway, wouldn't you guys say?
Old 11-27-2017, 06:44 AM   #5
james schaechter
I think Jim has run the 250 hp this year. Not saying it is the same car, I thought it was a 65. I would think a 250 would go 11.0s in a max effort car with great air and a tailwind! LOL.
The 283 220 post Deal is the lightest combo for a Nova v8 four barrel I think.
Old 11-27-2017, 10:15 AM   #6
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
The 2bbl engine in this car has a favorable power factor and fits Q at under 3000 lbs with the driver. The 4bbl engine has an unfavorable power factor (65 hp difference between the two engines). The only spec difference between the 2bbl and 4bbl engines is the intake-carb. I would be tempted to try the 2bbl first since the opportunity to work out the car and associated parts would have the advantage of not being so behind the ball performance wise with other competitors in the class.
That being said, the intake manifold is a serious limiting factor on the 2bbl engine.
Old 11-27-2017, 11:17 AM   #7
Dwight, I didn't realize the stick hp was so high in 64, Stock. Auto is probably better now.
I think that's what we're talking about anyway.
Jim, Are you talking to yourself? ;-)
