Old 11-02-2017, 01:13 PM   #1
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
Default Re: 2017 to 2018 Rule Amendments
Originally Posted by btrc View Post
I would think it would be better to have listed an index or class break-off. As it is you can have two cars in the same class, maybe even the same combo, that would have different rules. One that runs 10.98 needs the shield and one that runs 11.02 doesn't need one.
Absolutely not! All safety rules should be based on E.T. and mph. Physics is unaffected by what decals are on the windows. There's always going to be a line where there are additional safety requirements. It makes far more sense to have one line, instead of numerous arbitrary lines.
This is one of major problems that NHRA has now. The "index or class"-based safety rules that they currently have allow one 275hp combo to go 10.00 with a roll bar, -1 firesuit, etc, while mandating that another 275hp combo running 10.80 must have a full roll cage, -5 firesuit, competition license, and many other things. That is simply indefensible.
Old 11-02-2017, 03:09 PM   #2
novassdude
Liked 136 Times in 49 Posts
Excellent point. It makes sense. Problem is it is easier for tech to look at the decal on the window than figure out what each car actually runs. With the direction NHRA tech is going we know what way they will choose.
novassdude is offline   Reply With Quote
Old 11-02-2017, 08:42 PM   #3
Michael Beard
Looking at the dial-in on the window is even easier.
Old 11-02-2017, 10:48 PM   #4
Jason
Liked 6 Times in 4 Posts
There is no dial-in on the window during qualifying.
Jason is offline   Reply With Quote
Old 11-02-2017, 08:59 PM   #5
Bob Schmalz
Bob Schmalz's Avatar
So we would put our dial-in on the window before going to tech ?
Bob Schmalz 3199 Stock
Bob Schmalz is offline   Reply With Quote
Old 11-02-2017, 09:18 PM   #6
reera
Liked 31 Times in 6 Posts
What do the metric guys do?
Only one place to get a shield. Tom waters race car products. Doesn’t clear case braces. On a 69 nova, it requires cutting/modifying floor pan more than rules allow for stock eliminator just to get it to fit. Run a blanket instead? This ain’t tractor pulling. Bye bye 350, hello 6 banger. V/SA here I come.
Ryan Walther
Stock 315
reera is offline   Reply With Quote
Old 11-02-2017, 10:23 PM   #7
Casey Miles
Liked 507 Times in 92 Posts
Instead of worrying about blankets and shields, put a standard trans in your cars and see what fun it is racing and shifting gears. With Jericho and Gforce transmissions, reliability is at it's best. The biggest problem is figuring out the clutch, it's cheaper then converter's because you buy one and work with it. Breakage is minimal these days and repeatability is pretty easy.
Just a suggestion.
Casey Miles
248H Stock
Old 11-03-2017, 05:39 AM   #8
Shaun Quill
Liked 105 Times in 26 Posts
Just a suggestion.
Casey Miles
248H Stock
Amen!!!!!
Old 11-08-2017, 08:06 PM   #9
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
Ryan Walther
Stock 315
Ryan, same with a Corvette. Blanket's got to be hotter and usually when fluid gets hot, it spits it out.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
