Liked 28 Times in 15 Posts
Found a 0.030 over 454 2-bolt block with ARP main studs already installed. The studs are hard to turn out and I thought ARP says to install them hand tight into the block without bottoming them and not use loctite or anything to hold them in. So my question is will those studs being installed like that a problem or should we just check the crank bore alignment? Thanks ahead of time guys.
