Old 04-05-2017, 05:08 PM   #1
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: Fairmont U/S Build AKA Craigslist Racer
Not sure how happy the radials are going to be on a stick car. I tried it a few years ago, about every 4th- 5th run it would blow them off with no possibility of recovery. I had to run them down to around 12 lbs, wouldn't work at all at the typical 20 lbs that the auto guys run. I don't know of any stick cars that are having any luck with this.
Jim Caughlin
SS 6019
Jim Caughlin is offline   Reply With Quote
Old 04-05-2017, 06:43 PM   #2
Shadylane
Shadylane's Avatar
Liked 171 Times in 51 Posts
Jim Caughlin
SS 6019
Since my car is a fairly light, low HP car, I'm hoping they will work. They came recommended by a couple of guys. Guess I'll find out.
Thanks
Shadylane is offline   Reply With Quote
Old 04-06-2017, 11:53 AM   #3
Paul Wong
Liked 419 Times in 85 Posts
Thanks
The radials are a great idea, but it would really make your life a lot easier to start with a bias tire and get the clutch close. Then progress to the radial.
I have noticed the same thing with the radial that 1 out of 5 times it spins bad.
Paul Wong is offline   Reply With Quote
Old 04-06-2017, 07:06 PM   #4
Jim Caughlin
Radials were a tick faster, as I mentioned, I had to run them down to 10 - 12 lbs to get them to work. My car is low HP and light also, the only difference is that I have a boatload of low gear ratio. I guess my point is that you're not going to win a lot of rounds playing Russian Roulette on which pass they are going to spin. And when they do spin, it's not a recoverable spin, I have short shifted into second and had them continue to spin even then.
Jim
Old 04-06-2017, 08:44 PM   #5
Shadylane
Shadylane's Avatar
Jim
I will take your advice and look for some Bias tires to start with and maybe try the Radials at a later date.
Thanks, gentleman.
Old 04-06-2017, 09:25 PM   #6
Kelly, I tried radials with a stick, over 20 years ago. Too much torque and too much clutch.It bounced all over the place.
I would revisit that idea on a lighter, lower hp car, for sure.
But the guys are right. You've got enough to think about on the first day out.
Old 04-12-2017, 07:43 PM   #7
fred goodwin
fred goodwin's Avatar
Liked 35 Times in 11 Posts
Wow the car looks great Kelly! keep us posted and good luck!
fred goodwin is offline   Reply With Quote
