Liked 5,124 Times in 1,953 Posts
Looking great,Kelly
I know there are a few guys here that are really looking forward to seeing your car go down the track. You've got to make it to Wild Horse for the Association race in September. Let me know if you are coming down this way sooner. Oh, and don't worry about the stacking and parking thing. That's just a bunch of grumpy old guys carrying on. ;-) We never have a problem. Just ease in there whenever. The smaller the rig, the less the problem. See you soon.
Liked 275 Times in 76 Posts
Your making progress! A couple of things to consider. A momentary button to turn on the fuel pump for the fuel sample. And a ballast bar, depending on how light you were able to get the car. A ballast box will not get you to your natural weight, if the car is really light. Let me know if you want more info.
Sean
Liked 805 Times in 245 Posts
Not sure how happy the radials are going to be on a stick car. I tried it a few years ago, about every 4th- 5th run it would blow them off with no possibility of recovery. I had to run them down to around 12 lbs, wouldn't work at all at the typical 20 lbs that the auto guys run. I don't know of any stick cars that are having any luck with this.
Jim Caughlin SS 6019 |
#4 | |
Liked 171 Times in 51 Posts
Thanks |
#5 | |
Liked 419 Times in 85 Posts
I have noticed the same thing with the radial that 1 out of 5 times it spins bad. |
Radials were a tick faster, as I mentioned, I had to run them down to 10 - 12 lbs to get them to work. My car is low HP and light also, the only difference is that I have a boatload of low gear ratio. I guess my point is that you're not going to win a lot of rounds playing Russian Roulette on which pass they are going to spin. And when they do spin, it's not a recoverable spin, I have short shifted into second and had them continue to spin even then.
Jim |
#7 | |
Thanks, gentleman. |
Sean, I already put the momentary button on the car. I'll work on the ballast bar idea.
