Old 12-28-2007, 11:27 AM   #1
TS310C
Default Re: Pro Vs Full Trans Brake?
Sure you can. That is what they make delay boxes for. Set the car up for a pro tree and add delay when you run a full tree.
There are several things you can do for a quicker reacting car:
1. Pro Brake
2. Shorter front tires
3. Raise launch RPM
4. Change 4 link settings
5. engine location
6. Stiffer side wall in your slicks
7. Practice!
TS310C is offline   Reply With Quote
Old 12-28-2007, 12:02 PM   #2
Dave Steltz
Dave Steltz's Avatar
Tony, just cause I'm curious....
How much delay are you running in you car now on a full tree ?
Are you gonna run some local races on the .400 tree or divisional/national events ?
Reason I ask about what events, is, here in the east its really a .370 tree, not sure how to explain that, but the tree was sped up for the pro's to keep them from going red, and back here it rolled over to the divisional events also...So even us guys who were hitting the .400 tree ok had to do some work to hit the .370 tree in light SG cars...and you say (ss/sg) keep in mind the Super Street tree is .500...
Also is the front tied down ?
Dave Steltz 135G SG/SP/SST
BIAECH Racing Team
Dave Steltz is offline   Reply With Quote
Old 12-28-2007, 01:51 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Take note of what everyone has said & remember converter selection has quite a bit to do with reaction time. You usually have to work with your combination. It's a package deal.
Adger Smith (Former SS)
Old 12-28-2007, 02:24 PM   #4
TonyNewberry7274
TonyNewberry7274's Avatar
1.000 delay, And the front is not tied down. It has a lot of front travel. I plan on running some 6.0 heads ups and some super/street div. I forgot about the .500 tree in s/s. On the conveter selection, that is were I was worried about messing up the bracket combonation.
Newberry Body Shop
Weiner Ar. 72479
870-684-7274
TonyNewberry7274 is offline   Reply With Quote
Old 12-28-2007, 03:34 PM   #5
Dave Steltz
If you can hit the full tree with 1.0 delay today, you should have no problem hitting a .500 pro-tree as is...
Pull the chip out and put 45 lbs of air in the front tires and let 'er rip...You might also try adding some air to the rear tires to speed it up...
I didnt see how fast your car is but if you are going to use a throttle stop to run the 10.90 class kill it right off the line and you're good to go...
BIAECH Racing Team
Old 12-28-2007, 03:39 PM   #6
TonyNewberry7274
Why 45lbs? And the 6.00 class is on a .400 tree.
Newberry Body Shop
Weiner Ar. 72479
870-684-7274
Old 12-28-2007, 03:48 PM   #7
Dave Steltz
More air in the front tires will give you a little less rollout, and if you were just doing the .500 tree it would save you from buying shorter tires...
On the .400 tree I believe that you will need to get some shorter tires to hit it and tie the front down some..
One way to look at it, you would need to have 1.100 in your delay box on a full tree to simulate a .400 tree..
BIAECH Racing Team
