Liked 309 Times in 173 Posts
Probably the best on the market would be Weldon. I like what I see with Aeromotive, the A2000. IMO
Liked 73 Times in 36 Posts
Basic problem with QJets is the single needle and seat and the very small bowl volume. Take a look at the MagnaFuel stuff. It is hard to beat and their regulator has the best "droop" curve in the industry. Of course, just like anal ports and opinions......everybody has one.
![]() Regards, Dissident ![]() |
Liked 27 Times in 19 Posts
What pressure & size inlet seat do you guys use?
I would talk to Danny Ashley.
Ed Wright 4156 SS/JA |
Liked 799 Times in 236 Posts
Larry, changing to a bypass setup on my QJet stocker and running a #8 line back to the tank stabilized the fuel pressure. The fuel and pump are both cooler since the pump isn't pounding away on the same fuel like in a dead head regulator setup. Unless you've changed pumps since your build, you're also using the Quick Fuel #30-175 pump?
Thumbs up for Danny Ashley, as well. ![]()
"That'll never work....." |
Liked 260 Times in 102 Posts
Alan, Yes, you are correct about fuel pump. What bypass reg are you using?
Liked 1,916 Times in 574 Posts
Larry,
Q jets like high flow and low pressure. I run 6 lbs at the regulator. My set up is old school. 2 holley type blue pumps, 2 # 8 lines to the front and an Aerospace regulator # 8 to the carb. dead head. This has been very reliable. As far as carbs go if you can get your hands on a Boburka carb there is none better.
Mike Pearson 2485 SS |
