Old 07-30-2016, 09:43 AM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: 1965 Impala BBC Stocker Update
Finished boring the 396 Stock Eliminator motor by Vignogna Performance by James Vignogna Jim Aligned Honed, decked now bored, heading for the final honing on the Sunnen.
Old 07-31-2016, 06:17 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Did you fill the block? What casting number? Did you sonic test the block?
I have a database of 396 blocks and their characteristics.
Old 07-31-2016, 11:36 PM   #3
So you guys calculated the exact amount to deck the block?
Old 08-08-2016, 01:24 PM   #4
impstocker
impstocker's Avatar
Answers to last 2 post.
Dwight the block was not filled but passed sonic testing. I don't have casting # om me but know it is a 1965-1966 block. Has ungrooved rear cam journal, we will groove the cam I have. Also have canister type oil filter, will get adapter for spin on.
Mark yes we did. Basically cam up with same deck height the original 396 had. I will be using the rotating assembly from that motor too.
Will
Old 08-08-2016, 03:05 PM   #5
Dwight Southerland
Will - Probably a 961 block. I have found those to be mostly good. At least they don't have the core tilt I have found in a lot of the '67-'69 blocks. Good luck!
Old 08-08-2016, 07:32 PM   #6
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: 1965 Impala BBC Stocker Update
I've got 3 2 bolt main 396 blocks out in my store room. I'll look at and write down the numbers and we'll ID what they are. You got me curious.Isn't there a grooved rear cam bearing available to enable the use of the later cam in the early block? I know that a 409 has a grooved rear journal on the camshaft itself.That must be where they got that from on the early 396.
Old 08-08-2016, 08:53 PM   #7
Greg Reimer 7376
Two of the three blocks are # 3855961. Both have fully grooved rear cam bearings.The other block is #3969854. It has also a later screw on oil filter,the other two have canister type filters.
Old 08-09-2016, 08:14 AM   #8
Alan Nyhus
Liked 799 Times in 236 Posts
3855961 blocks are '65-'66 396. Interestingly, some '66 427's also had this casting
number.
3969854 is a '69 396 and was also used in the '70-'72 402's.
"That'll never work....."
