Old 12-12-2007, 09:08 PM   #1
LouisJeffery
Question Re: And the whiner award goes to ......
Typical Chevrolet 350 such as 295hp. 1967 production cam spec .390 .410 NHRA spec .390 .410
Typical mopar 340 production cam spec .429 .444 NHRA spec .462 .473
Not hating just trying to keep it REAL!!!! What happened there ? is it just a 30 year old typo??????
Louis Jeffery 3225 STK
LouisJeffery is offline   Reply With Quote
Old 12-12-2007, 09:44 PM   #2
Real Racer
Default Re: And the whiner award goes to ......
Cheverolet 350 cam specs in question are a far cry from the ones you chose to list.
Here are the 71 Z28 cam specs
330 350 .002 Flat w/n 2023/1605 458/484 Outer w Damp .016 887,316,993,916,881,882
Real Racer is offline   Reply With Quote
Old 12-12-2007, 10:01 PM   #3
Ron Ortiz
Ron Ortiz's Avatar
Liked 317 Times in 103 Posts
Clutch man, thanks for the go ahead, I was a little worried. By the way, have I met you before at the races, I believe I know you from your previous posts and your location.
Ron Ortiz
U/SA jerky head huh.
Ron Ortiz 2102 STK
Ron Ortiz is offline   Reply With Quote
Old 12-12-2007, 10:14 PM   #4
LouisJeffery
Wink Re: And the whiner award goes to ......
My post was not about any particular combo just the DIFFERENCE between the actual factory cam lift and the NHRA (Paper car) spec of the Mopar. Doesn't the 340 run against the 290 hp 350 Chevrolet in E,F,G and H stock?
Old 12-13-2007, 12:53 AM   #5
Speedracer
Smile Re: And the whiner award goes to ......
I am really impressed with the 1968 340 combo running as fast as it does with the factory 1.815 Piston Compression Height.That is truly outstanding! It really shows what HARD work can do!
The Chevrolet has a big advantage with a 1.535 compression height.
Speedracer is offline   Reply With Quote
Old 12-13-2007, 10:26 AM   #6
Greg Hill
Liked 279 Times in 68 Posts
Merry Christmas Chuck. At least you won't have to run against Jerry Bennett any more.
Greg
Old 12-13-2007, 11:54 AM   #7
Harry 6674
Chuck Beach, how much have you picked up your combo over the many years you've worked with it? What do you feel was the biggest technological boost through the years? Its got to be tough when you have a combo with out a lot of options. You have to love it.
Harry 6674 is offline   Reply With Quote
