Old 03-15-2016, 11:42 PM   #1
Lou Jeffery
Default Re: c4 build
The parts you have listed are a good start. The key to a high torque high RPM C-4 is replacing the thrust washers with Torrington thrust bearings. Once that is under control you may consider a manual shift fixed line pressure valvebody. The traditional shift kit with vacuum modulator line control and governor can be marginal with that much engine power. The Ford C-4 is an excellent transmission, It is light weight, fits well and has reasonable durability.
Lou Jeffery is offline   Reply With Quote
Old 03-16-2016, 06:26 PM   #2
Moparteacher
I appreciate the responses.
Gary Weaver
Moparteacher@yahoo.com
Moparteacher is offline   Reply With Quote
Old 04-12-2016, 04:29 PM   #3
ShadowLands
ShadowLands's Avatar
Ditto.
ShadowLands is offline   Reply With Quote
