Old 02-01-2016, 10:14 AM   #11
SSGT Mustang
Liked 204 Times in 54 Posts
Default Re: 79 Mustang project U/SA
The '94 brakes may not be legal. I thought that the '94 went to a different spindle type, which may cause a problem. I don't know, but you may want to check if making the spindle change is considered cross-breeding parts. It may not matter, since aftermarket brakes are allowed. However, the spindles as I recall are very different from the 79-93 spindles, as are the rotors.
If you do run into problems, I have a set of 5 lug rotors and gt calipers that I would donate to you. You have to pick up the shipping costs. I had the caliper pistons coated by Swain, and solid inserts installed. The rotors have 1/2" long studs and new bearings. They spin pretty well.
They're available to you if you need them.
SSGT Mustang is offline   Reply With Quote
