Old 01-28-2016, 09:38 AM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default Re: Hot Rod class question
Ron welcome, as Cal said member ship & H/R number. The 135 mph thing is NHRA I believe. Min weight 2600lbs. All your safety stuff needs to be up to date helmet 2010 snell number min. Depending on how fast your car is you may need a throttle stop and a delay box if you run a trans brake. Your car will need sfi harmonic balancer, sfi flex plate & shield, and a sfi trans shield. But all these you should already have if you run 10.90 or quicker hope this helps.
Old 01-28-2016, 11:59 AM   #2
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
Snell 2005 should also be accepted this year.
S/ST 51
S/C 53
Old 01-28-2016, 01:55 PM   #3
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
Thanks for the replies. I'm good on all the safety stuff except for the flex plate shield. I didn't know it was a requirement in Hot Rod. The dates on the trans shield, balancer, and flexplate have passed. Do they check those dates?
Ron Gusack is offline   Reply With Quote
Old 01-28-2016, 02:00 PM   #4
Ken MacNicol
Ken MacNicol's Avatar
Liked 26 Times in 12 Posts
No shield needed if stock firewall
Ken MacNicol is offline   Reply With Quote
