Old 11-30-2015, 11:33 PM   #1
jmantle
Liked 172 Times in 81 Posts
Default Re: Going DEEP....
I never heard of a vote. If the racers voted, at least in SS, it would get voted down. Almost nobody could get a green light staging that deep. They don't make buttons THAT slow. LOL
Those of us who run slower stockers would benefit from being able to deep stage.
As we are in the minority, we lost the vote. I have to leave when I see the second amber going out, not an easy thing to teach an old racer.
Jim Mantle V/SA 68
jmantle is offline   Reply With Quote
Old 11-30-2015, 11:44 PM   #2
JOE ZOOM
Liked 43 Times in 15 Posts
Originally Posted by jmantle View Post
those of us who run slower stockers would benefit from being able to deep stage.
As we are in the minority, we lost the vote. I have to leave when i see the second amber going out, not an easy thing to teach an old racer.
Jim mantle v/sa 68
x2
JOE ZOOM is offline   Reply With Quote
Old 12-01-2015, 04:35 AM   #3
Maverick
Liked 36 Times in 26 Posts
The sportsman classes should be just like the pros. You only need one light to start, and that is the stage. The problem to me is racers putting deep on the window, and expect special treatment, when they stage. It is something extra that is not needed or wanted. The prestagr was to just tell you , your getting close to the stage. It adds to the confuline, easily when the slower time wins the round due to reaction time being lower and a slower et. I think NHRA did it to take out some of the variation in this technique of rolling. It is stupid to me that I roll in and the prestage goes out and I am staged, but I go red. Just because I let the top bulb go out. If the rule is that great, then the pros should do the same thing. I have to roll in to get good lites, and I run super gas. If the top bulb flickers I am red. But if the bottom bulb flickers, cause you too shallow, well I believe that have a fix in the timing system for that, and you don't go red. I want it just like the pros. I roll in and the top bulb goes out, so what I am staged. Also could be for the rule is that you know where you are when the top bulb goes out, and can adjust you delay, or what ever to be even better. Let's race and do it like the pros. I believe it would liven thing up on the starting line
Old 12-01-2015, 07:40 AM   #4
Pinballer
Pinballer's Avatar
Liked 13 Times in 7 Posts
At the local tracks I've been to, if a competitor wants to stage deep, as a racer courtesy he is -expected- to get in there and get staged first so as not to "hold up the show". Much like Jim Mantle stated, I already know from past experience that if forced to shallow stage, I too will have to leave in between the second and third yellows in order to cut a good light with a 14 second 6 cyl car. The reason for a deep stage in my world is simply to adjust where I leave on the tree, not to get closer to the finish line. Even though I've always had slow cars, I just wanted on leave on the last yellow like everybody else gets to do!
But its OK, I'll figure out the adjustment either with shorter tires or brain cells..been through the wars many times before.
As far as deep staging being an advantage--you have to run what's written on the window or slower so I don't see that being an issue as far as ET is concerned. Doesn't mean a deep stage guy will always cut .00_ lights either.
Yeah, I get where a fast car can ET slower than what they're fully capable of if they're in deep, but the only time I can see that really meaning anything is when you can run 1.20 unders or better at will.
Brian Saunders Lerna IL
'79 AMX T/SA 3790 currently being resurrected
Pinballer is offline   Reply With Quote
Old 12-01-2015, 08:31 AM   #5
Billy Nees
Liked 7,781 Times in 1,743 Posts
Funny, I've never had a problem shallow staging. I didn't deep stage when I could.
I would rather see NHRA do away with the pre-stage bulb then go back to allowing deep-staging.
Billy Nees 1188 STK, SS
Old 12-01-2015, 09:34 AM   #6
JOE ZOOM
Talking Re: Going DEEP....
Hey Billy....you were lucky to have a mentor like Ed to teach you the rope.
Old 12-01-2015, 10:04 AM   #7
Billy Nees
You don't mean Eddie, the King of the Deep-Stagers do you?
Old 12-01-2015, 12:23 PM   #8
Ed Wright
Ed Wright's Avatar
That applies to slow cars as well. That means something even if you can barely run the index. Bracket racers started doing that many years ago for that very reason. Not for their lights.
I had a car so slow once I had to leave when the 4th (old tree) amber went out. Just something you have to learn to do if your car is that slow. You learn to do whatever your car requires.
Some of us have to use a blinder, and even block the top half of the bottom bulb to try to get a green light. Yes, that helps a little.
Ed Wright 4156 SS/JA
Old 12-01-2015, 12:30 PM   #9
Billy Nees
Ed(Wright not Fernandez), that's why you're one of my heroes!
Old 12-01-2015, 12:30 PM   #10
Ed Wright
Ed Wright's Avatar
Billy, you don't have that bar set very high.
